Timing
Ian
There is a large table which determines ignition advance based on RPM and g/cyl air mass which is another way of saying load. So at 1500 rpm under light load, say cruising on flat ground at 60 mph, 35 degrees may be OK +- a few degrees. But at 3500 rpm with any boost, you will not be OK with 35 degrees of advance.
25-28 degrees of advance is the range for non-boosted engines. So if you run 25 degrees advance at WOT with any boost, that probably is way too much and you will definitely see lots of knock and timing being pulled out.
Your AFR is targeted by the PCM to be at 14.69 during light throttle (cruise) to maximize fuel economy. But once you start opening up the throttle, seeing boost, the PCM should be programed to go richer...somewhere between 10-12 depending on many things including RPM, load, boost level, timing, engine coolant temp, inlet air temp, etc.... Your headers glowing red should tell you to STOP RIGHT NOW and find the problem and fix it.
