C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
2.5bar map sensor problem
Old Dec 7, 2009 | 04:30 AM
wishmaster's Avatar
wishmaster
Default 2.5bar map sensor problem
Hallo,
For my C6Z06 2008 ECS2200 running 14psi with 80lb injectors on pump gas yet,so i have decided to go with 2.5bar map sensor as many adviced ,but now i need the VE tables or not sure what more will be required !! for that can anyone kindly put them in excel format so i can gave them to my tuner !!
as per him it will take him more than 6 hours as he need to start from scratch !!
my tuner use HPT
Really wish if any can help me on that as my car since yesterday at dyno for nothing
pls email me at tahnoon3@hotmail.com
Old Jan 2, 2010 | 01:19 AM
akshaya's Avatar
akshaya
3rd Gear
Freescale Semiconductor MPX4250AP 2.5 bar MAP sensor. This is the standard sensor used on the MegaSquirt kits. Useful as an atmospheric pressure sensor when used with continuous barometric pressure compensation in MSnS_Extra and MS II.
sonic vs naruto Copiers
Old Jan 3, 2010 | 03:24 PM
INTMD8's Avatar
0INTMD8
Former Vendor
It does take quite a bit of time to build the VE tables from scratch.
I've sold many 2.5bar base files to other shops to get them started and can do the same for you if you're interested.
jim@speedinc.com
847-891-0767
To 2.5bar map sensor problem
