C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
LS3 MAP Sensor Question
Old May 9, 2010 | 12:07 AM
matthud's Avatar
matthud
Default LS3 MAP Sensor Question
What is the stock limit of the LS3 MAP sensor? I can't find a definitive answer, I have seen 1.5bar, and 2bar. What is the true limit? And does anyone have the voltage vs pressure scale.
Thanks.
Old May 9, 2010 | 11:28 PM
TurboLX's Avatar
TurboLX
The sensor's physical limit is about 128kPa (1.2bar), but the diagnostics clip that a little bit. You'll see that the software basically stops counting around 105kPa (1bar) since the factory never intended that sensor to be used on anything other than atmospheric pressure.
If you're running a turbo or supercharger, the LS9/LSA MAP sensor is a direct swap that only requires a change to two values in the PCM to make it work perfect. This sensor is good for about 300kPa (3bar).
Old May 9, 2010 | 11:32 PM
matthud's Avatar
matthud
So does that mean the sensor is at 5v at 128kPa?
To LS3 MAP Sensor Question
