Quick question
My question is; how do I decouple the Predator from my car without screwing up the tune that is on it? I may sell the car so I want to put the Predator back to clear so it can be used on another vehicle.
If so, thats not possible, restoring the stock tune to the car is the only way to unlock the Predator so it can be sold. The only real option I see is to sell the Predator with the car otherwise it will not run.
I contacted you guys after I bought the Predator and you referred me to a CMS tuner because I could not use the Predator on my CAM'ed car. I had the car retuned and they stored the tune on the Predator. The car previously had a EFI live tune.
I never had a stock tune on the Predator so as far as I know, the CMS tune done by "Delk Performance" should be the stock tune? Am I wrong?
What I want to do is clear the Predator have the CAM removed and program the car with a new code. My way of seeing it is that if I have the CAM removed, the current tune that the Predator thinks is original will render it useless.
so, if you/they imported a custom tune to the predator and installed said custom tune to the car, then yes - the stock original backup tune is saved on the predator...
so, now your options are:
#1 - leave the car as is and sell the predator along with it...
#2 - remove the cam from the car and put the original stock cam back in it, and then "restore original backup" from the predator to the car in order to unlock/reset the predator from the car, then sell 'em both separately...
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS LS3, short-throw shifter, NPP perf. exhaust, BMR strut-tower brace, Cold Air Inductions cold air intake, catch-can, ported/polished TB, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
