C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
clearing a code by pulling a fuse ?
Old Aug 11, 2010 | 01:12 PM
FNBADAZ06's Avatar
FNBADAZ06
Default clearing a code by pulling a fuse ?
I understand you can clear a CEL notification by pulling the power from the ECU for 15 minutes. Can this be done by pulling a specific fuse or can this only be done at the battery connection ?
Old Aug 11, 2010 | 02:09 PM
BearZ06's Avatar
BearZ06
St. Jude Donor '09 thru '17,'22 thru '26
Just go to A-zone or another like parts store, they'll read and clear it free. Don't know about the fuse thing but I doubt it will clear it.
Old Aug 12, 2010 | 03:16 PM
ian@thetuningschool's Avatar
0ian@thetuningschool
Former Vendor
Pull the battery. But do you know what the code if for?
Old Aug 12, 2010 | 03:43 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
It may turn the dash light off but the code will still be in history. I echo post#3. Do you know what the code is? If it's still "bad", it'll come right back.
Elmer
Old Aug 12, 2010 | 08:16 PM
FNBADAZ06's Avatar
FNBADAZ06
Elmer
code P0101 MAF . I'm thinking it might be to an over oiled airfilter element on my KB, so I ran some CRC MAF Cleaner thru the sensor. I want to clear the CEL and see if it returns.
Old Aug 12, 2010 | 09:33 PM
Former Vendor
So you have a Kenne Bell on your ZO6? How long have you had that setup for?
Ian
Old Aug 12, 2010 | 09:47 PM
FNBADAZ06's Avatar
FNBADAZ06
Ian
Sorry for confusion bud...KB as in Killer Bee
Old Aug 12, 2010 | 09:57 PM
Former Vendor
Lol thats a my bad , im spending to much time on the Mustang Forums . Did you clean the filter lately? It could also be that the ECM is more airflow then it should, when is performs a check on the Throttle Body.
Old Aug 12, 2010 | 11:18 PM
FNBADAZ06's Avatar
FNBADAZ06
Yes, it was recently cleaned and re-oiled. I also cleaned the MAF aftr first recieving the MAF code.
Old Aug 26, 2010 | 08:55 PM
schizcat's Avatar
schizcat
Remember one thing about doing this. if there is a true problem, pulling the fuse can only clear the problem. the problem will still exist. its like sweeping dirt under a rug. The dirt will just not be seen, but it is still there. best thing to do is find out what the code is and what it means and find a real fix. not sure what mods you have and what tune you have and what is controlled by the ECU, etc, but you dont want to give it problems to where it wont make everything run optimially and as it should with the tune, etc. just my $.02
Old Aug 26, 2010 | 09:09 PM
FNBADAZ06's Avatar
FNBADAZ06
I believe you still have to "clear" the CEL or code after the repair is made (I believe).
In my case, my belief is that an over oiling of my Killer Bee filter may have coated the MAF sensor so I cleaned it with CRC MAF cleaner and wanted to clear the code and CEL to see if it fixed the issue
Old Aug 26, 2010 | 09:51 PM
schizcat's Avatar
schizcat
ok, may have misunderstood all the other post but that makes sense. i am not really sure if you have to clear the code after the repair of if they CEL\ECU\BCM or whatever is smart enough to know the problem has been resolved (knowing computers, probably not). The best thing I have found to clear codes is by pulling a cable from the battery. I am getting SAH (yes i have gone in for the recall) errors and SCL errors. I pull a cable, they go away. being that they are both still there, i do get the messages back once in a while. So with that info, I will be honest and say from my experience, it can go either way. I know, not too much help from this end, but it could give you a lead. I will let you know that I have read in the tech forums of people putting on CAI or changing to a different airfilter and throwing codes. They also said that they have changed back to their stock filter\system and the codes will go away. from a computer tech's point of view, you may want to try throwing the stock unit back on if you still have it and see what happens. I know its a pain, but its a start.
Old Aug 26, 2010 | 11:18 PM
FNBADAZ06's Avatar
FNBADAZ06
Yep, my Killer Bee is causing my P0101 MAF error...after over a year and a half of install time Put my original airbridge and filter back on with the same MAF sensor and the error/CEL has gone away.
Old Sep 14, 2010 | 12:25 PM
FNBADAZ06's Avatar
FNBADAZ06
UPDATE:
I recently purchased the full version of Rev2 program for the iPhone, which allows you to clear any stored codes and to review emission readiness status values. You have to purchase an ODBCII WiFi interface to communicate with the iPhone app, but this app will also allow you to perform some modest data logging with an export feature !!!
I used this app to review and clear any codes I had stored in the ECU and to monitor IAT's, timing, fuel trims, and throttle position when at the track.
Cool little app if you have an iPhone.
http://www.devtoaster.com/products/rev/
Old Sep 14, 2010 | 09:55 PM
dennis50nj's Avatar
dennis50nj
UPDATE:
amazing
To clearing a code by pulling a fuse ?
