C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Target AFR for E85
Old Sep 1, 2010 | 12:13 AM
dfinke23's Avatar
dfinke23
Default Target AFR for E85
What AFR at WOT are you guys running with E85?
Old Sep 1, 2010 | 08:14 AM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Not sure if you know how the PCM calculates the fueling but here goes.
E85 stoich is calculated like this:
Ethanol Stoich: 9.0 x 85%= 7.65
Gasoline........: 14.7 x15%= 2.21
Stoich for E85:.................9.86
So, at lower throttle openings, the A/F ratio is 9.86.
But the PCM to references stoich as "Lambda" which is 1.00 so all you have to do is set the stoich to whatever fuel you are using and the rest of the PCM setting are good.
There are a number of tables for enrichment and they simply work off of Lambda. For example, the PE table multiplier to achieve 13.0:1 for 100% gas is 1.13 (14.7 / 1.13=13.0). So using Lambda then becomes .88 (1 / 1.13=.88).
I know this is a little confusing. For more information, pick up the tuning books written by Greg Banish.
Old Sep 1, 2010 | 08:59 AM
DSteck's Avatar
DSteck
If you're NA, I'd shoot for somewhere between 0.75 and 0.80 lambda for E85.
Old Sep 1, 2010 | 09:26 PM
hex's Avatar
hex
Depending on the blend ( from e70 to e85), part throttle stoich is 9.7-9.9. I have run as lean as 10.2 at PT.
Wide open throttle power AFR range is 6.9 to 8.6.
Remember, the blend affects it greatly, and will vary from summer to winter.
Your 2008 should adjust accordingly.
Hope this helps you.
Jim
Old Sep 20, 2010 | 09:19 PM
seevi's Avatar
seevi
8.2 - 8.3
Old Sep 22, 2010 | 04:21 PM
ian@thetuningschool's Avatar
0ian@thetuningschool
Former Vendor
Wish we got E85 down here in florida.
Old Sep 23, 2010 | 09:09 AM
robz's Avatar
robz
If possible, to make it less confusing tune on the gas scale. This will also give you finer adjustments (more resolution).
Knowing that above,
I would start @ 12.5:1(gas scale) afr OR .85 Lambda.
Pump e85 may not be 85% ethanol but even the race guys have seen very little difference with varying grades on the same tune.
Old Sep 24, 2010 | 07:16 AM
seevi's Avatar
seevi
Knowing that above,
The operative word in this sentence is Lambda. Lambda for E85 is not the same as gasoline, especially pump gas. E85 has a stoich value of about 9.65, therefor 85% of Lambda would be about 8.2 for WOT.
Old Oct 5, 2010 | 02:11 PM
Cunningham Motorsports's Avatar
0Cunningham Motorsports
Former Vendor
i run them generally between lambda .84 -.87 depending on the setup amd useage of the car
Old Oct 5, 2010 | 03:49 PM
Mike@DiabloSport's Avatar
Mike@DiabloSport
Supporting Vendor
Poppin up all over the place here in WPB/FT. Laud.
Old Oct 6, 2010 | 02:01 AM
dfinke23's Avatar
dfinke23
Road racing, 468 NA LS7, 12.25:1 comp?
Old Oct 6, 2010 | 08:51 AM
DSteck's Avatar
DSteck
0.80-0.85 lambda. Push it around and see what it wants.
Old Oct 8, 2010 | 05:55 AM
dfinke23's Avatar
dfinke23
What plugs are you guys running with e85?
To Target AFR for E85
