C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Engine Computer Question
Old Oct 20, 2010 | 07:31 PM
breecher_7's Avatar
breecher_7
Default Engine Computer Question
Ok, here is my question. I am well aware that GM started lojacking there ECM's in the 2007 model year of the diesel trucks and there was information stored in them such as regeneration count and the TCM stored info such as max calculated torque at the transmission as well as tracking the CVN#'s. Making it impossible for people to use flash tuners to increase power because even if you purchased a second ECM the regen count and other things would be out of spec.
My question is what tattle tales do the 2010 corvette computers have in them if any? Do they track the CVN's? Is there anything else they track that would look odd if you swapped the computers for dealer visits? Idealy I would like to take out my factory computer and replace it with a secondary. Simply and intake and exhaust car with a nice tune. Then I could put the factory computer back in for factory visits.
Not exaclty the most honest thing to do, but its not like im changing out hard parts, just bolt ons.
I have HP tuners and am capable of doing the work myself, just need to know if this is a safe option as I dont want to loose my warranty over 20-30hp.
Old Oct 21, 2010 | 01:46 PM
06MonteSS's Avatar
06MonteSS
Supporting Vendor
yes, they have the same type of things, same as the camaro's do...
plus, there is other info stored in the ECM, one such item being mileage, and if that doesn't match up with the odometer or other modules, then bingo, they gotcha...
so, swapping ECM's is out of the question now too... so yeah, can't do that...
not to mention the fact that, you can't even get a new ecm for it... some camaro guys have tried, and they can't even get them... GM's not letting them out...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS LS3, short-throw shifter, NPP perf. exhaust, BMR strut-tower brace, Cold Air Inductions cold air intake, catch-can, ported/polished TB, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Oct 21, 2010 | 05:29 PM
breecher_7's Avatar
breecher_7
The E38 ECM is very much available, i can get them at $180 a pop. What exactly do they store? Last time I checked milage was only stored in the cluster.
Old Oct 22, 2010 | 01:07 AM
06MonteSS's Avatar
06MonteSS
Supporting Vendor
"GM Publically admits Odo in ECM - Symptoms of Module Swapping" --
http://www.camaro5.com/forums/showth...hlight=mileage
http://www.sandyblogs.com/techlink/2...l-modules.html
Old Oct 22, 2010 | 06:31 AM
breecher_7's Avatar
breecher_7
Well thats no good at all! Back to the drawing board!
Old Oct 22, 2010 | 11:01 AM
06MonteSS's Avatar
06MonteSS
Supporting Vendor
hehe...
To Engine Computer Question
