My experience is that the launch control does not really work after 100+ HP is added. The car just breaks the rear loose almost as much as without launch control engaged.
Wondering if anyone has found a way to reflash the ECU to adjust the launch parameters to provide better control.
Launch control is on the manual only. And it is garbage.....I followed the instructions to the letter & all my car did was spin like mad.
"Launch Control"....forgive me guys...but are you talking about the traction control ??? The little yellow car with squiggly lines behind it? I find that MY stock C6 doesn't work too well... I can imagine after the A&A SC I put on it.. !!!
Am i thinking the same thing ?? trac Cont... is Launch control ??
No,Chevy added a launch control system starting in 2010 to all manual Corvettes.
