C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Engine Light
Old Jan 1, 2011 | 06:40 AM
puma421's Avatar
puma421
Default Engine Light
My C6 engine light comes on and off intermittingly. Off for a few days then on for a few days. Dealer ran the scanner on it and found nothing wrong, reset the computer, but still acting up, on and off. Any help on curing the prob? Thanks,Walt
Old Jan 1, 2011 | 01:14 PM
REVAK's Avatar
REVAK
If the scan did not show a code, then it is considered a "soft" code and probably not serious, most likely emissions related. Once an actual code appears it is considered a "hard" code and the number indicated can be crossed referenced to a particular component or event. Until the light comes on and stays on, you won't know for sure.
Old Jan 2, 2011 | 06:12 AM
puma421's Avatar
puma421
Default Engine Light / Revak
Thanks for the info. I am going to the dealer Monday and try again.
To Engine Light
