C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
ignition without start
Old Dec 1, 2011 | 09:55 AM
PA_BLUE_C6's Avatar
PA_BLUE_C6
St. Jude Donor '05-'10-'12, '15
Default ignition without start
Good morning all,
I need to get my efilive hooked up with iqnition on without starting the engine. Besides stalling the engine, is there a way to do this.
08 manual
TIA,
Noe
Old Dec 1, 2011 | 10:09 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Push the start button but don't press in the clutch. I do it all the time to get a total recording of every engine rpm. I have EFILive recording before I push in the clutch and hit the start button the 2nd time.
Elmer
Old Dec 1, 2011 | 10:25 AM
PA_BLUE_C6's Avatar
PA_BLUE_C6
Thank you, I just was not sure if the ignition was on because I am getting a "no connection" error. Now I will concentrate on fixing my connection protocol within efilive.
Thank you for quick response.
Noe
Old Dec 1, 2011 | 10:43 AM
eboggs_jkvl
Moderator emeritus
Noe
Got the latest updates 7.5 & 8.1? Boot Blocker? HAPI, Firmware? Lots to keep current and totally happy I had to sit down last week and update the entire enchilada to get it all to work.
What is included in the download:
EFILive ScanAndTune: V8.1.2
EFILive Explorer: V8.1.2
EFILive HAPI: V8.1.2
FlashScan boot block: V2.07.01
FlashScan firmware: V2.07.xx
EFILive Scan Tool: V7.5.6
EFILive Tuning Tool: V7.5.6
Elmer
Old Dec 1, 2011 | 11:54 PM
PA_BLUE_C6's Avatar
PA_BLUE_C6
Wow, I did not have enough beers to even to start. Three beers later, I'm all updated and ready to validate the PID's. My EfIive rusty skills are done for to night, so tomorrow I will hook to port and establish comunication.
Thanks again for your help,
Noe
Old Dec 2, 2011 | 04:49 PM
csun213's Avatar
csun213
Default For Auto?
For us A6 guys, do we just push the start button without stepping on the brake?
Old Dec 2, 2011 | 05:45 PM
j_digi454's Avatar
j_digi454
No, just push the start button on the bottom as if going into the ACC mode and hold in that position for 5-6 seconds until all the accessories come on including the heater/AC and headlights if your in the garage. You are now on (not in the ACC mode) without the engine started or running.
I do this when I use HP Tuners to read or flash the ECM which I believe the OP wants to do. I believe you can use the same procedure for M6's as well although I never tried it.
Old Dec 2, 2011 | 08:40 PM
csun213's Avatar
csun213
Thanks for the information.
To ignition without start
