Suspension Mods & Performance - www.PartsTaxi.com
Former Vendor
20822934 - Upgraded Metal Sway Bar End Links - $24.98 each
Z51 Front and Rear Sway Bar Kit - Our most popular bar kit. Kit includes front and rear stabilizer bars and bushings for Z51. We are now proud to offer our customers the choice or either OEM bushings, or polyurethane (poly) bushings from Pfadt Racing for the same price of -$199.88
ZR1 Front and Rear Sway Bar Kit - Kit Includes front and rear sway bars and insulators $209.82
Z06 Front and Rear Sway Bar Kit - Kit includes Front and Rear Stabilizer Bars for C6 Z06 and insulators - $226.85
T1 Sway Bar Kit
T1 Sway Bar Kit includes front and rear T1 bars and bushings - $559.10
Options available when ordering;
Optional C6 Metal End Links - $91.12
Or
Optional T1 Fully Adjustable Metal End Links - $219.00
C6 Z06 Shocks
10313647 - Front Shock - $59.96 each
25819268 - Rear Shock - $58.67 each
That's only $237.26 for all 4!!
Z06 Springs
25909895 – Z06 front spring – $252.23
15233392 – Z06 rear spring – $270.95
T1 SACHS Shocks
Front - 12480094 - $169.88 each
Rear - 12480095 - $169.88 each
That's $649.08for all 4!
T1 Springs
Front - 25534418 - $849.38
Rear - 25534419 - $849.38
Eibach Pro Kit - 38126.510 C6 Lowering Bolt Kit - $71.95
These can be adjusted to stock ride height or up to 2" lower, making these a great replacement for broken spring bolts not available through GM.
Hotchkis Suspension
Hotchkis Sport Suspension C6 Sway Bar Kit - 2284 - $399.95
Bilstein
B6 Heavy Duty C6 Front Shock - 24-029759 - $87.99 each
B6 Heavy Duty C6 Rear Shock - 24-029766 - $87.99 each
B8 Sport C6 Front Shock - 24-029773 - $87.99 each
B8 Sport C6 Rear Shock - 24-029780 - $87.99 each
Koni
Koni FSD Series Non Adjustable Shocks (set of 4) C6 - 2100-4053 - $759.95
Koni Sport Adjustable Shocks Front C6 (pair) - 3013-1023Sport - $679.99
Koni Sport Adjustable Shocks Rear C6 (pair) - 3013-1024Sport - $679.99
QA1
QA1 Front Shock C6 Non Adjustable - TN510 - $85.95 each
QA1 Rear Shock C6 Non Adjustable - TN705 - $85.95 each
QA1 Front Shock C6 Single Adjustable - TS510 - $165.99 each
QA1 Rear Shock C6 Single Adjustable - TS705 - $176.99 each
QA1 Front Shock C6 Double Adjustable - TD510 - $259.95 each
QA1 Rear Shock C6 Double Adjustable - TD705 - $279.95 each
QA1 Corvette "R" Series Front Shock Adjustable - TR510 - $179.95 each
QA1 Corvette C6 Single Adjustable Pro Coil Over Front System - GS402-09550 - $499.99
QA1 Corvette C6 Single Adjustable Pro Coil Over Rear System - GS403-07550 - $579.99
QA1 Corvette C6 Double Adjustable Pro Coil Over Front System - GD402-09550 - $678.99
QA1 Corvette C6 Double Adjustable Pro Coil Over Rear System - GD403-07550 - $769.99
QA1 Corvette C6 Drag Race "R" Series Pro Front Coil Over System - GR402-9550 - $535.99
Thank You! We look forward to working for you!
Kevin Cassimore
www.PartsTaxi.com
T1 Sway Bar Kit
Or
C6 Z06 Shocks
Z06 Springs
T1 SACHS Shocks
T1 Springs
Hotchkis Suspension
Bilstein
Koni
QA1
Kevin Cassimore
www.PartsTaxi.com
Former Vendor
Former Vendor
