C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Ignition On
Old Jan 9, 2012 | 12:24 PM
Hells's Avatar
Hells
St. Jude Donor '08
Default Ignition On
Is there anywhere where I can find, in writing, the process to get the vette's ignition on without starting the engine? I know you just hold the button down for a few seconds but I am trying to find somewhere where I can find the procedure for it.
Old Jan 9, 2012 | 12:37 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Manual or auto?
Manual, just push it like you are starting it but don't push in the clutch.
Auto, I haven't a clue.
Old Jan 9, 2012 | 12:51 PM
Hells's Avatar
Hells
St. Jude Donor '08
It's an A6 but I know how to do it. What I'm looking for is something in writing where the process is described. Would I find it in AllData or a repair manual?
Old Jan 28, 2012 | 01:59 AM
3musky3's Avatar
3musky3
looks like in 07 gm changed ignition mode operation. if i understand right you hold mode switch in acc position until entire vehicle turns on without engine running? is this how your s works? i found this in service info. i am a gm tech. if you go to your chevy dealer and ask them to print document #2476470 that is where i read this info at.
To Ignition On
