C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Pulled fuses now problem!!!
Old Jan 16, 2012 | 04:42 PM
bwill03z's Avatar
bwill03z
Default Pulled fuses now problem!!!
I pulled fuse 25 and 29 for about 10 minutes in hopes that it would clear the service column lock msg that ive been getting and when i put them back in and turned the ignition to run the "corvette by chevrolet" "service column lock" and "pull key wait 10 secs" messages were all scrambled.. all the letters were jumbled up and out of order... whats goin on here??
Old Jan 16, 2012 | 04:54 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
disconnect the battery
Old Jan 16, 2012 | 05:08 PM
bwill03z's Avatar
bwill03z
I waited a little bit longer and tried it again, everything is correct now. I was freaking out a little there for a min. Unfortunately, still getting service column lock msg :/
Old Jan 26, 2012 | 06:16 PM
ssv3's Avatar
ssv3
I think you're talking about a C5. You can get a lot more info there. Good Luck!
To Pulled fuses now problem!!!
