C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Tuning question
Old Mar 12, 2012 | 01:43 PM
Funkybird's Avatar
Funkybird
Default Tuning question
Im pretty new to tuning but I purchased hptuners for my 06z and have made some small changes, so far so good. Im ready to get my afr dialed in on the street before I head to the dyno. My question is, can you accurately log afr in a gear thats not 1:1, for instance 2nd gear?
Old Mar 12, 2012 | 03:06 PM
stanger383's Avatar
stanger383
St. Jude Donor '09
yes you can but you wont have the same load on the car as you would in high gear. If you race your car and log it will be through every gear that you hit and then you can see how consistent it is anyway
Old Mar 12, 2012 | 03:48 PM
Funkybird's Avatar
Funkybird
So I would probably be better off in fourth gear it sounds like. I won't be able to dial it in as close as I thought before the dyno if thats the case, thats some serious speed going wot through 4th.
To Tuning question
