C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
need help code P0106 C6 ZO6
Old Mar 23, 2012 | 09:18 PM
C6ZO6-2006's Avatar
C6ZO6-2006
KaNDriZO6
Default need help code P0106 C6 ZO6
hello
i have big problem in my car get code P0106
P0106: Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
i buy a new map but the code not go before the code the car is very nice after come the bad code and i check in the Hp tuner the gauge work
the car every things is change
1- not good idle
2- cam lean 17 - 18 in my gauge aem Cruise before the code 14
3- down 2000 rpm very hard drive
i check the vacuum and the intake maybe have leak but everything's good
the car 441ci with black widow
thanks
Old Mar 24, 2012 | 08:40 PM
ChevyDave's Avatar
ChevyDave
P0106: Manifold Absolute Pressure (MAP) sensor signal not within predicted range for 2 seconds.
Inspect for:
- restrictions in the MAP sensor vacuum source
- MAP sensor seal missing or damaged
- vacuum hoses disconnected, lose, or incorrectly routed
- intake manifold leaks
- vacuum leaks at the throttle body
technical info, mostly same as above...
http://www.obd-codes.com/p0106
f.y.i. if you have e-force supercharger and outside temp is less than 20 degrees, it can throw that code (mine did), but your location, doubt temp is ever a concern.
Old Mar 24, 2012 | 10:21 PM
C6ZO6-2006's Avatar
C6ZO6-2006
KaNDriZO6
Inspect for:
thank you very much
To need help code P0106 C6 ZO6
