Maxiumum agreeable boost with a blown LS2
Hi guys,
i have a blown LS2 Vortech V7, callies crank kit, forged pistons,...
Till now i had about 21 psi without problems.
Now i want to change to the new procharger F1X but i feel angry that the boost (about 26 psi) is too much for this motor block?
What is the maxiumum agreeable boost with a blown LS2?
I heared that one guy cracked the cylinder sleeve with this blower.
What do you think?
Thank you
What do you think?
Thank you
Will work for HPDE time.
Boost is such a one-dimensional value.
Your motor should be fine to 12-1500 rwhp or so with forged guts, assuming all is balanced and matched. Are you using 1/2" studs, thick-deck heads and o-rings? Lifting the heads is what will kill you.
Boost is a measure of restriction, not a direct connection to power output/gains. Generally speaking, upping the boost will net more power, but after a certain point the gains are not the same per pound of boost.
