C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
evap code
Old Apr 18, 2012 | 07:21 PM
sea six's Avatar
sea six
Default evap code
I have an 06 LS2. I installed a m112 supercharger a few years ago. I have been getting a code P0455 and a GAS CAP on DIC warning. I have replaced it twice but still have same issue. Is there something in the vacuum lines or a valve that could have gone bad. Car runs great but have a problem with CT emission.
Old Apr 18, 2012 | 09:21 PM
ChevyDave's Avatar
ChevyDave
This indicates a fuel vapor leak or lack of purge flow in the EVAP control system. It means a large leak has been detected. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.
http://www.obd-codes.com/P0455
other posts...
http://forums.corvetteforum.com/c5-t...post1575303318
I did a parts list, seriously i have no clue if something in this is the value (sorry), maybe someone can point it out..
http://parts.nalleygmc.com/showAssem...=evap canister
Old Apr 19, 2012 | 08:16 PM
sea six's Avatar
sea six
Thanks Dave. I will do some inspecting this weekend. If anyone else has some ideas they would be appreciated.
To evap code
