C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Need Help, Running really rough, pulled codes
Old May 26, 2012 | 04:18 PM
DietCocaine's Avatar
DietCocaine
Default Need Help, Running really rough, pulled codes
Hey, my 2005 C6 with 55k miles has been running really rough for the last 5k miles. It has an occasional rough idle, smells like gas, and under hard acceleration black smoke will come from the exhaust. I had the codes reset, drove on the highway and these are the faults that returned:
Fault: P0301
Pending Fault: P0174
Any help to fix this problem will be greatly appreciated!
Old May 26, 2012 | 06:45 PM
ChevyDave's Avatar
ChevyDave
http://www.obd-codes.com/P0301
http://www.obd-codes.com/P0174
Old May 27, 2012 | 05:59 PM
ChevyDave's Avatar
ChevyDave
let us and the person having identical problem know how you solved your code(s)..
http://forums.corvetteforum.com/c6-c...-to-start.html
Bill has tec info on P0174 here (interesting further down where it talks about gaps/holes near air baffle) http://forums.corvetteforum.com/c6-z...check-eng.html
To Need Help, Running really rough, pulled codes
