beginner tunning
beginner tunning
I'm new to tuning and would like some input on what to look at first on tuning my stock ls2 c6 m6. I have a borla cat back and efi live. Waiting on wide band. Anything I can adjust with out wide band?
http://forum.efilive.com/forum.php
You can program your fans to come on sooner to run a bit cooler, with the M6 you can disable the 1-4 skip shift as well as turn off the dash indicator, can remove all or a portion of Torque Management, timing a bit including reducing some of the timing retard tables like Intake Air Temp (IAT) and Engine Coolant Temp (ECT) as well as tune the non-wide open throttle fueling (AFR) via the Long Term Fuel Trims (LTFT)and Short Term Fuel Trims (STFT).
Will need to become familiar with both the Tuning as well as the Scanning software. As Josh stated, the EFILive and HPTuners forums are a great place to find information and have your questions answered. I would only recommend that you ask specific questions to an item, not "How do I tune?"
Good luck and welcome to the dark side
Ed M
Ed M
Ed M
Ed M
Absolutely, and thanks! I have been reading a lot and there is so much information out there it is kind of overwhelming. The first thing I'm wanting to do is get it running cooler via 180* stat and twin fan kit. What all needs changed in the computer for this? Also I'm fabbing up my own cold air intake, my friend has a cai and had to have it tuned because it was throwing a lean code. If I am understanding correctly you have to adjust the mass airflow for the cai?
Any time you change the air capabilities (intake, Headers, CAM etc.) of the engine, you need to retune your MAF/VE across non-wot and wot.
Ed M
Wednesday is opening night...against D! tough schedule this year for sure. Atleast we dont have to deal with TEBOWMANIA
Say Hi, see ya soon
Ed M
All is well my friend....how are you guys doing? Missed Carlisle this year...work stuff. Missed our body shop/paint projects Smiley is good, busy and some neat projects this year.
Say Hi, see ya soon
Ed M
Say Hi, see ya soon
Ed M
