C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Intune programming question
Old Sep 23, 2012 | 01:01 AM
cookoff's Avatar
cookoff
Default Intune programming question
One of the programable options on the intune for my 09 A6 is "Rev Speed limit". There are then two subsettings. "Rev limit in gear" and "speed limit on or off". Rev limit in gear seems to be self explainatory, but to be sure can some one explain both of these so that I can set appropriately?
Old Sep 24, 2012 | 10:30 AM
Mike@DiabloSport's Avatar
Mike@DiabloSport
Supporting Vendor
its just as its described...
Rev limit in gear allows you to raise or lower your engine rev limiter, and speed limit on/off allows you to disable the factory based Speed limiter.
