C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Header install
Old Mar 31, 2013 | 06:28 PM
ROID11's Avatar
ROID11
Default Header install
Just installed headers and its not runinng propely. However im not dropping $600+ for a dyno/tune. I need to purchase/borrow a unlocked tuner to get the stubling low RPMs fixed . Any Ideas?
Old Apr 1, 2013 | 03:44 PM
Boltfan555's Avatar
Boltfan555
St. Jude Donor '12
Is that all that is done to your vette? I installed my headers and had no driveability issues. I did eventually get a tune done, but not until months later.
Old Apr 2, 2013 | 07:23 AM
ROID11's Avatar
ROID11
Its more of a idle issue. Runs as of it has a cam. think its because the rear O2 are off. Im calling Chuck COw today. Maby run up to see him soon.
Old Apr 2, 2013 | 08:17 AM
1MEANGS's Avatar
1MEANGS
why not ECS?
Old Apr 2, 2013 | 10:41 AM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Come on up and we'll check it out for you....
Its more of a idle issue. Runs as of it has a cam. think its because the rear O2 are off. Im calling Chuck CoW today. Maybe run up to see him soon.
Headers won't usually cause a "CAM" type idle, but I'd be afraid you've got a cracked
plug or bad wire after the install or maybe you changed the intake and something's not aligned right.
Either way, while it seems like child's play to install headers....most every set that comes here that was
installed elsewhere or at home has some major boo-boo that requires fixing BEFORE tuning.
When you plan to come up, we should both budget a few extra hours to be sure everything is right
BEFORE getting the tune dialed in.
No sweat. We'll get it right.
Call when you're ready.
Chuck CoW
Old Apr 26, 2013 | 02:20 PM
truckplay's Avatar
truckplay
Default is the "mil" on ?
sounds like a missfire. see if the spark plug wires are snapped onto the plugs & coils, then check your plugs, you may have cracked one.
Old Apr 26, 2013 | 02:29 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
and or 02 sensors switched banks if you have LG's.
The car should run fine after a header install, check engine light in time, not at it's peak performance, but it should run fine.
To Header install
