C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Help with obd ii code c0073
Old Apr 2, 2013 | 09:55 PM
rganders's Avatar
rganders
Default Help with obd ii code c0073
Recently I replaced my driver side front fender. Since then I have an intermittent driver side airbag indicator on the dashboard with an accompanying obd ii code c0073. I found c0073 described as an ABS driver side solenoid #1. I suspect that I have disturbed the wiring on the driver side front collision sensor. Has anyone else experienced this scenario. Any input would be appreciated by me. Thanks Randy Anders
Old Apr 4, 2013 | 06:39 AM
rganders's Avatar
rganders
I am mistaken. C0070 and c0075 describe malfunctions of drivers side ABS solenoids 1 & 2 respectivety. Would it be safe to assume that c0073 is an indicates some malfunction in this same area?
