C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
E92 read support added
Old May 29, 2013 | 01:29 PM
foff667's Avatar
0foff667
Former Vendor
Default E92 read support added
http://www.hptuners.com/forum/showth...9A-ECM-support
What this means to you:
If you own or know someone that owns a vehicle that uses one of these pcm's do a read entire using the newest public build 2.24.105 or newer and send us the .hpt file as well as a vcm suite infolog so that we can start mapping these calibrations.
Upon reading out the pcm you will likely receive a "File failed validation check" error or "definition failed to load", don't worry, its perfectly normal, just send us the file & infolog, those errors are perfectly normal.
Where do I get this update?:
Right on your customer page www.hptuners.com/customers even though the 2.24 link is dated for march something its autoupdated with any new compiles we create so simply download & install.
What if I get some other error?:
Email support with a screenshot of the error along with a vcm suite infolog while connected to the vehicle in question
What vehicles does this E92 pcm cover?:
2014 Chevy Corvette
2014 Chevy Silverado V8
2014 GMC Sierra V8
There are likely others this is just through our initial research of these pcm's though I'm sure this extends to others.
-Bill
