What are the changes that normally need made to the tune when adding long tubes with hi flow cats?
I have HPS Tuners Pro and had a custom dyno tune done by Ed Hutchings previously. I plan to have the car dyno'd and send the logs to him but was curious what changes are almost always needed when doing the headers?
Not much. Dial the air fuel back in if it has changed. I have seen some setups take another degree or two of timing with less restriction in the exhaust.
With hi flow cats you probably want to turn off all the bank 2 o2 codes because they can trip sometimes. May need to kill the cat efficiency code too.
I usually dial back the cat over temp enrichment with hi flows. Something around half what the factory is.
What he said above. Also, if the decel popping bothers you, adjusting the timing tables under DFCO helps. I just use the settings from a ZR1tune and that pretty much takes care of it.
