C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
erratic timing question
Old Aug 1, 2013 | 09:36 AM
JRS 94's Avatar
JRS 94
Default erratic timing question
2008 A6 - timing is jumping from 14 to 6 then to 20 degrees at idle causing an obvious erratic idle condition. Car has a supercharger and headers. Where would you start? Crank sensor? Tune has been reviewed and pretty much ruled out. Thanks.
Old Aug 1, 2013 | 09:39 AM
Mike@DiabloSport's Avatar
Mike@DiabloSport
Supporting Vendor
No codes?
Cam/cranks sensors should be checked for sure.
I assume it was fine at some point, then suddenly developed this problem?
Old Aug 1, 2013 | 10:44 AM
JRS 94's Avatar
JRS 94
no codes, yes it was fine until the blower install, I'm thinking a sensor got damaged.
Old Aug 1, 2013 | 11:38 AM
Mike@DiabloSport
Supporting Vendor
blower install, and tune at the same time??
No offense, but who verified the tune?
If it was the person who did it, I might seek a second opinion.
If you told me the blower was installed and tuned, then it drive fine for a day/week/month, I'd say there is no way its the tune, but if it happened at the same time, and you have no clean driving experiences since the blower was installed (and presumably tuned) it is tough to say.
Generally, a broken or damaged sensor will lead to a check engine light.
Old Aug 1, 2013 | 12:25 PM
Unreal's Avatar
Unreal
Tune, intake leak, spark issues.
Then again, spark at idle isn't suppose to be rock solid. Jumping is normal at idle.
Old Aug 1, 2013 | 01:44 PM
JRS 94's Avatar
JRS 94
Its a long standing issue since the install, original vendor didn't fix the car so I'm with a second.
Car was reflashed and tune started over with the second shop, found BOV spring keeping BOV closed at idle, 2 plugs and wires checked poor, now finally this erratic idle is all thats left. We see the timing changing when it shouldn't, hence going after things that affect timing. Its been a long year.
Old Aug 1, 2013 | 03:36 PM
Mike@DiabloSport
Supporting Vendor
drivability is otherwise OK?
Spark is under control when under load?
Old Aug 2, 2013 | 09:14 AM
JRS 94's Avatar
JRS 94
Learned that timing is moving around on the dyno pull as well. Changing the crank sensor wasn't it. Looking at the supplied injectors with the wiring adapters, (really loose) going to try some 65# FAST direct fit injectors today. Also learned that the miss travels around the cylinders using the tech 2 which is leading me toward this injector idea.
Old Sep 6, 2013 | 11:35 PM
PGSJOE's Avatar
PGSJOE
just got this addressed on my blower install.
second tuner found that the burst knock setting was too sensitive and the duration of the retard was too many cycles.
My engine is noisy becase its all forged now so I was ready to pull my hair out because of the surging.
Burst knock is a prelude to spark knock so its a knock sensor - sensor if you will. Ask your tuner to look at this if he/she is willing if not get a better tuner.
The burst knock episode would trigger a timing retard that lasted to many degrees or cysles (revolution of crank) before it corrected itself. this variation is the surge you are feeling and seeing on the tach. good luck hope this helps
Old Sep 24, 2013 | 11:19 AM
JRS 94's Avatar
JRS 94
Thanks I'll ask about this, so far the BOV spring was wrong, keeping the valve closed at idle, and the check valve for the crankcase was backwards, which caused issues on the dyno. Also installed a new inlet tube without the ECS radiator relief in it and that helped calm the MAF down. Getting better.....
Old Sep 24, 2013 | 11:31 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
I would be cautious with the FAST injectors, they are drilled out stockers, we will not use any drilled out injector here due to countless amounts of problems we have seen here from them.
You should have had brand new Motron's that came with the kit, we have never had an issue with one to date.
Old Sep 24, 2013 | 11:35 AM
DOUG @ ECS's Avatar
DOUG @ ECS
"Radiator Relief" in the intake tube??
Old Sep 25, 2013 | 10:56 AM
vrybad's Avatar
vrybad
I'm guessing he means the pancaked area over the radiator.
Old Sep 26, 2013 | 06:28 PM
TARANTULA's Avatar
TARANTULA
Disable spark smoothing
Old Sep 26, 2013 | 11:45 PM
JRS 94's Avatar
JRS 94
Yes the pancaked area, with that tube removed and replaced with a round un-pancaked tube the maf settled down and the car idles fine at 550 rpm. ECS kit supplied injectors are on the car, the bov spring is changed to the green spring, and the check-valve is installed correctly now. Car is fixed, too bad I had to change installers to get it finally done. Thanks to Finishline Performance.
To erratic timing question
