Need TechII help / confirm something.
I need to confirm a sensor reading a techII. This is the steering wheel position sensor. What are the correct range of readings. I need readings from left to right and right to left. My tool (non techII) reads 0 - 465 turning to the right (which is correct) and stays at 720 turning to the left. The GM manual states it varies , so I would like to know what is the correct range. On a 2010 camaro I get 0 - xxx turning to the right and 360-xxx lower numbers turning left. Thanks if you can help out. A 2011 or 2012 gransport may be similar not sure. Thanks if you can confirm a reading.
This sensor should be part of the EBCM ( electronic brake control module)
