C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
detonation and spark plugs
Old 05-16-2014, 11:48 PM
trbomike
trbomike's Avatar
Default detonation and spark plugs
last race season I took my 06 auto base to the track. I have a Intune. With the 93 tune I got a bunch (like 12 degrees or more) spark. I upped the fuel (wbo2 12.8) and back the timing down. It helped but still knocked. I've tried different brand fuels, etc but am still getting detonation. I can actually hear it at times. I installed the 91 tune, same thing. Thinking of a spark plug change, maybe going 1 step colder. the car has exhaust and varraram. any ideas on the issue? what plugs should I use? thanks in advance.
Old 05-17-2014, 12:11 AM
tennblkc6
tennblkc6's Avatar
you running good 93 octane fuel? stock plugs? are you data logging? have you tried richening up the mixture to ~12.2?
Old 05-17-2014, 12:31 AM
trbomike
trbomike's Avatar
Yes, tried many different brands. I did datalog.. Yep, richened it up
Old 05-17-2014, 03:16 AM
C7/Z06 Man
C7/Z06 Man's Avatar
If your engine uses the 41-110 as the LS3 than you could try the LS7/LS9 41-104 or whatever is the next cooler iridium plug for your engine is.
Also I have read here that the "carbon treatment" which makes a lot of smoke has worked wonders for those that have had problems getting rid of knock. I don't want to mention names but that advice iirc came from a guy who knows how to make serious hp. PS: I have never tried to de-carbonize any of my engines so I have no experience to offer.
Old 05-17-2014, 08:11 AM
tennblkc6
tennblkc6's Avatar
can you explain what you mean by you were seeing 12° of spark? do you mean at wot or what?
Old 05-17-2014, 08:54 AM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
I would check your cats for blockage.
Old 05-17-2014, 10:12 PM
trbomike
trbomike's Avatar
Sorry..it was pulling 12 degrees of timing
Old 05-17-2014, 10:34 PM
CTD
CTD's Avatar
I started a thread way back when regarding cooler plugs, TR 6. Back to back plug change only.
To detonation and spark plugs
Quick Reply: detonation and spark plugs
