Just curious:
has anyone on here with an automatic c6 with H/C/I had a problem where you sitart your car and the rpm's are working find.
Drive car for awhile but once you cut it off and start it back up the rpm guage lays over on the crank up ... but lays flat at idle . Car then goes into a boating mode and the code p0336 pops up when you scan it.
If you clear the code the rpm's still doesnt work but if you let the car sit for awhile the rpm guage will enventually start working again . Now once the car runs awhile and you cut the car off again its back to no rpm's . Thanks any info would be highly appreciated !!!!!
crankshaft position sensor or ignition coil issues
Thanks bro .... changed the crank sensor but will definitely check the ignition coils !!!! All this started after a timing chain failure but I will get to the bottom of it
great. good luck and please update the thread with the outcome.
