C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Code P0689??
Old Mar 22, 2015 | 02:59 PM
phylrick's Avatar
phylrick
Default Code P0689??
Have noticed nothing wrong with he car......Checked codes just to see if any had hit over the year. P0689 showed up and I suspect the fact I used a float charger over the winter. Does anyone agree??
Car is a 2005 Base with ARH 3" X-pipe back to Corsa Sports., Supercharged (Edlebrock E-Force.....Dyno at 680 at wheels.).
Old Mar 29, 2015 | 06:55 PM
Hib Halverson's Avatar
Hib Halverson
Pro Mechanic
Pro Mechanic
If the MIL is NOT on, clear codes, road test. If the MIL stays off, I wouldn't worry about it.
Old Mar 30, 2015 | 09:32 AM
Speedforhire's Avatar
Speedforhire
On my 2013 GS this code is turned off by default (3-no error reported).
P0689 = ECM/PCM Power Relay Sense Circuit Low
Old Apr 12, 2015 | 09:35 PM
phylrick's Avatar
phylrick
Default yep---seems to have......
I cleared the code and your right never reappeared.......still wonderng if it could have been the float charger??????
Old Apr 19, 2015 | 12:27 PM
Hib Halverson
Pro Mechanic
Pro Mechanic
On an 05, P0689 will set if the key is in run and the battery voltage is low so no...it's not because of your float charger unless the battery is faulty and the float charger cannot keep it charged such that when the key is in Run or On the system voltage is below 10V.
What it may indicate is your battery is weak.
Have it tested and replace as necessary.
To Code P0689??
