C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
C6 Dyno Tune Question
Old Jul 20, 2015 | 11:54 AM
Booman's Avatar
Booman
6th Gear
Default C6 Dyno Tune Question
I had my 2007 Corvette dyno tuned and is in the delaer for some work. If they disconnect the battery, will it effect the tune at all? They tell me it will not.
Old Jul 20, 2015 | 04:41 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
It will not.
Old Jul 20, 2015 | 06:19 PM
Booman's Avatar
Booman
6th Gear
Many Thanks!!
Old Jul 20, 2015 | 09:53 PM
mowton's Avatar
mowton
Nope, some of the trim data and such may be lost, but you will drive a bit and they will be reconfigured.
Ed M
Old Jul 21, 2015 | 08:51 AM
Booman's Avatar
Booman
6th Gear
Thanks for the reply Ed.
Old Jul 24, 2015 | 12:12 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I agree the more modded your engine is the longer it will take for your fuel trims to re learn -- at most maybe 50-75 miles of normal driving---Typically cold air intakes the most common mod will make your engine to constantly add fuel at P/T to correct--No big deal at P/T however as a lean safety that same % will be added to your WOT fuel as well until it learns out---resulting in RICH WOT fueling and a lazy top end---after it learns out no fuel will be added to WOT and all is well
To C6 Dyno Tune Question
