C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
dreaded p0300 code
Old Jun 29, 2016 | 08:57 PM
548chevelle's Avatar
548chevelle
Default dreaded p0300 code
got an '11 Z06 with CAI, Magnaflow exhaust and an Intune canned tune. Been running great for 3+ years. Changed the oil 2 weeks ago and when i started it up I got the P0300 code. It went away after 3 engine starts. But a couple days later it came back. Now 5-6 engine starts its still there. My question is whats a good way to troubleshoot without having to buy an expensive scan tool. I have the Diablo Intune and also an OBD dongle. I downloaded a couple apps for my Adroid tablet. Torquelite and I've been using OBDLink to monitor engine stuff. Whats a good app to analyze whats setting the code?
Old Jun 29, 2016 | 09:19 PM
77vette05's Avatar
77vette05
Same thing happened with my 05'. Check the spark plug wires. Make sure there all clicked on the coils and plugs. One of my spark plug wire felt a little loose on the coil. I pushed it back on and the code has not come back on. Good luck.
Old Jun 30, 2016 | 12:53 PM
06MonteSS's Avatar
06MonteSS
Supporting Vendor
plugs, plug wires, coils...
make sure no cracked plugs.. and no loose plugs..
make sure wires are all fully snapped on to the plugs/coils..
clean your MAF sensor..
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS LS3, short-throw shifter, NPP perf. exhaust, BMR strut-tower brace, Cold Air Inductions cold air intake, catch-can, ported/polished TB, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Jul 1, 2016 | 11:30 AM
arc6's Avatar
arc6
Just went through the same thing changed the plugs and code is gone .
Old Jul 1, 2016 | 08:49 PM
548chevelle
I've only got 5000 miles on the car. Seems unlikely to be plugs. Besides wouldn't there be a code that pinpoints the offending cylinder? I'll check everything out. Just seems strange this came on right after changing the oil. I cleaned the MAF two years ago when I took out the K&N air filter which is oiled. I switched to a non-oiled AirRaid. I remember taking readings before and after. The gms/sec at idle dropped from 11 to 9.
Old Jul 3, 2016 | 10:12 PM
548chevelle
I was using a set of Taylor 10.5mm plug wires. So I figured I would go back to the stock set. The Taylors are very difficult to seat on the plugs. I think two were not fully seated. But I continued replacing them with the stock set. Also figured I'd check the plugs. WTF! They were all gapped from the factory at .035. Supposed to be .040 so I did that. Started engine and no code. Drove it 3 different times today still no code. I'll wait a week or two and go back to the Taylors and see what happens,
To dreaded p0300 code
