One More Wideband Q
One More Wideband Q
I am going with dashlogic. I have tons of info from past threads and some input from some members here. Just to make sure, with Dashlogic (OR, HPT scanner) I am only going to need a WB controller such as the Innovate LC-2 3877; or AEM 30-0310. Correct?
I found an old 2015 thread where a table was produced. It showed response times, but from what I concluded, any of the "controllers" listed would work with Dashlogic? or as a scan adjunct if I use HPT scanner?
Here is the chart? Thanks once again guys. I am dropping the hammer on these items right now and don't want to be down a wrong path.
Received 1,194 Likes
St. Jude Donor '15
Any of those should work, obviously you don't want the slowest ones on the list. Wideband O2 sensor connects to controller, controller has 0-5V out that connects to dash logic or HPT (typically)
The controller will come with the controller, a gauge if included (sometimes the controller/gauge are one unit), O2 sensor itself and wiring to hook it all up.
The AEM one you'd want now is probably 30-0333 though, it's an updated version of the one at the top of that list, it connects to the OBD port and can connect to HPT over that instead of with a separate 0-5V wire/signal. That's what I'm using now with HPT.
The only negative is it doesn't come wired with a 0-5V out for connecting to dash logic. You can add two wires to it and get one, though. Not hard to do and the pins you'd need are like $0.02 literally
OK - Dashlogic is on its way. I am leaning toward the Innovate LC-2 3877. First step is to get the wideband installed, now that I have a loc for the WB bung (Thanks again guys!). After I am setup and reading data w/WB, then the last step is to purchase the HPT suite.
I am leaning in these directions based on what I am trying to accomplish. I am looking to complete and tweak 1 tune. I am sure I will never do another tune on another car. So, I am trying to make purchase choices that consider this.
Meanwhile, I am diving into the VCM demo suite every day. When I reach the point of VCM purchase, I want to practice datalogging with the scanner on my stock fac tune (reference/learning points for me). THEN I'll crack open the A&A, install, tune, tweak.
Dashlogic arrived today, missing the green analog connector. I've contacted the vendor. Does anyone have suggestions for a different source?
Also, does anyone know the thread size of the wideband Innovate LC-2? I have an 18mm bung, but don't have the WB yet. Want to make sure before I weld it.
Dashlogic is slick. I tried it quickly. Shows v1.21.
St. Jude Donor '15
M18x1.5 is the thread size you need
If you google 3 pin green terminal or connector you should find the right one.
I would also look into Tech-Edge. I have one of their 2C0B units on my C6 for around a year now and reliability and performance has been perfect. Response time is excellent as well. Not sure if the others you're looking into offer serial communications, but that feature on the TE unit is great because you don't have to worry about calibrating your ADC/DAC circuitry in whatever datalogging equipment you're using. Still offers analog output if you need it too.
