C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Throttle controller and Tune?
Old Nov 24, 2016 | 10:12 AM
mxw128's Avatar
mxw128
Default Throttle controller and Tune?
Would a tune take the place of what a throttle controller (like Sprint or Vitesse) does (remapping throttle curve)? So would there be any reason to leave a throttle controller installed if I got a tune to accommodate a set of LT headers? TIA
Old Nov 24, 2016 | 04:21 PM
Dcasole's Avatar
Dcasole
Yes a tune can do what a Vitesse does but......you will be stuck with just one setting, and it will be the setting that the tuner likes and might not be what you like , why would you want to loose the ablity to adjust your settings ?
Old Nov 25, 2016 | 10:24 AM
russ472's Avatar
russ472
its hard enough to find a good tuner, much less find one that can remap the throttle as well.
get your tune done and reinstall your Vitesse
Old Nov 25, 2016 | 03:30 PM
VitesseMotorsports's Avatar
VitesseMotorsports
Banned Scam/Spammer
You will need both a Tune and our Throttle Controller.
No, the Tune will not give you the same Throttle response you have now with our controller.
Old Nov 25, 2016 | 07:49 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Actually, it is now possible to adjust the throttle maps in HPTuners without getting all the errors that used to be an issue.
Though I agree the average person can't adjust it on the fly.
Old Nov 25, 2016 | 08:37 PM
Dcasole's Avatar
Dcasole
Yep that is the beauty of the Vitesse ... you can adjust it on the fly
I need to buy HP tuners and learn how to use it ....
Dave
Old Nov 26, 2016 | 08:52 AM
mxw128's Avatar
mxw128
Actually I have the competitor's controller I haven't had time to install it yet but need to..... wanna trade??? (thanks for the response though! )
Old Nov 27, 2016 | 02:41 PM
zrracer's Avatar
zrracer
St. Jude Donor '11, '14
IMHO a street tune with the tuner in the car is the way to go. For the tranny part of it my tuner set the d position for dinner with the gf and the s position for me. The other plus of course is getting engine tune perfect also.
Old Dec 1, 2016 | 12:03 AM
KM177122's Avatar
KM177122
"open source" is a great way to go.
Old Dec 6, 2016 | 04:46 PM
yellowmnm's Avatar
yellowmnm
It's my opinion, that you should keep your vitesse controller installed.
Make the tuner aware that you have it. My reason is, one thing the controller does is at high sport setting does increase the air flow over stock, so a tune would help a lot
schpenxel's Avatar
schpenxel
St. Jude Donor '15
It doesn't change airflow.
Old Dec 6, 2016 | 05:14 PM
Unreal's Avatar
Unreal
QFTT
No way a controller can change airflow.
Old Dec 6, 2016 | 06:41 PM
yellowmnm's Avatar
yellowmnm
Originally Posted by Unreal
QFTT
first do you guys even have one? second did you do any testing?
Depends on your cold air system. Most aren't sufficient so your right it starves for air.
My source is I talked to the owner of Vittesse He explained a lot to me.
also talked with westcoast DM of Granatelli He knew all about the Controller
He told me with most cold air systems because the blade opens so fast that the throttle body is starving for air.
So Hear say? I don't know they both did do some testing, basically told me very similar info, and thats their bread ad butter. So if their wrong I'm wrong!
Old Dec 6, 2016 | 06:48 PM
Unreal's Avatar
Unreal
Wow.
An electronic throttle controller cannot change airflow. What does a cold air system have to do with a throttle controller?
Old Dec 6, 2016 | 07:01 PM
Dcasole's Avatar
Dcasole
Wow.
Old Dec 6, 2016 | 09:41 PM
Unreal's Avatar
Unreal
Your wrong and they are wrong.
Old Dec 6, 2016 | 10:21 PM
russ472's Avatar
russ472
the controller opens the throttle blade so fast, the engine sucks the CAI into a vacuum.
There has been many informative post the last few days. Glad I have been on to learn. lol
Old Dec 6, 2016 | 10:26 PM
russ472's Avatar
russ472
just a thought, maybe when my controller is on 5... I can build boost, but on 10 it won't?
I might need to pulley down to keep up with the controller.
To Throttle controller and Tune?
