Pros/cons of tuning a LS3 maf only?
Looking for some feedback on MAF only tuning a LS3. The car is my daily driver and I'd like to know if there are any issues tuning this way. If the maf starts to fail is there a fail safe to protect engine?
Received 1,194 Likes
St. Jude Donor '15
MAF only can work. Generally SD is smoother which is more noticeable on setups with large cams or something with a lot of turbulence.
SD model is still used for transients (quick changes) so you really should still at least have the VE table in the ballpark.
Factory uses both. No reason you can't do the same other than not wanting to spend the time to do it.
1966427 (04-13-2017)
Is tuning both sides as simple as disabling maf, tuning sd, then disabling sd and tuning maf? I read bluetorps article(http://www.camaro5.com/forums/showthread.php?t=196696) on the camaro5 forum describing this process. Should I still follow that with the exception of using hp tuners virtual ve table instead of his software?
St. Jude Donor '15
I can't read the thread right now but in general, yes
Pros
Easy. Quick.
Cons.
It's the quick easy half *** way to tune. Maf doesn't like reverb or quick transients so fueling will never be as good as it could be.
Easy. Quick.
Cons.
You don't have to be in pure SD to calibrate the VE model. It requires some math, but otherwise fairly straight forward. I do it all the time. I tend to tune cars and leave them in blended mode. I do disable predictive modeling though.
1966427 (04-14-2017)
St. Jude Donor '15
hptuners forum, it has been posted there
or google GMVE, figure out the units and work backwards from there
St. Jude Donor '15
Depends on setup, but basically I'd say make spark safe, get fueling correct, play with spark, re-adjust fueling as necessary along the way
St. Jude Donor '15
Yeah for that not a lot to worry about as far as destroying something goes IMO, should be fine
Why are you not wanting to disable maf for ve tuning and visa versa? That's the way every book I've ever read teaches ya. Works great for me. Why make it more complicated than it needs to be?
Because it isn't more complicated. It is quicker/easier. Just set up formulas/math and then you don't have to mess with 2 different tune sessions, one with maf on and one with it off.
It's not that I dont want to disable maf to tune ve. I was talking about pros and cons of tuning maf only. Disabling sd and running the car maf only.
St. Jude Donor '15
Books are showing the simple way, not necessarily the fastest/smartest way. Either way can work.
Yeah I know that was your main question. My Z06 seems to run smoother with blended. Also, I figured GM does it for a reason so probably best to maintain it.
