C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Tuners please help!!!
Old May 9, 2017 | 07:27 PM
Carl Gatto's Avatar
Carl Gatto
Default Tuners please help!!!
Just finished the heads and cam swap on my c6Z. Took it to the tuner to find out the ecu is locked from the previous tuner!!! I've been told the dealership can factory reset the ecu allowing my tuner to access the ecu.... Is this true or have I been misguided thanks.
Old May 9, 2017 | 08:37 PM
russ472's Avatar
russ472
I believe the dealership would be blocked as well. You may have to get another ECU.
Old May 10, 2017 | 08:32 PM
BlindSpot's Avatar
BlindSpot
yeah, unfortunately a tuner lock is like a password on a computer. NEVER NEVER accept a tune from a shup that locks the tune.
Old May 10, 2017 | 09:41 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I thought a dealer could still flash it back to defaults with their stuff but I may be wrong on that one
Old May 11, 2017 | 07:10 PM
Dcasole's Avatar
Dcasole
I though so also ... cant a Real GM TECH II flash an ECM ?
Old May 12, 2017 | 08:26 AM
edmundu's Avatar
edmundu
I thought you could still flash the pcm regardless. The tune is locked, so you cannot read the pcm. You will need to purchase new credits, but I could have sworn you could perform a "write entire" with another tune that is not locked. Like another stock calibration.
Old May 12, 2017 | 09:07 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Don't think full write will work if it's locked, at least not on E38's. Seems like that was an option on the older gen 3 stuff but it's been a long time since I've messed with those
Old May 12, 2017 | 10:25 AM
edmundu's Avatar
edmundu
I searched, and you are correct...once locked, they cannot be overwritten with tech II or HPTuners.
Old May 20, 2017 | 06:16 PM
DSX Tuning's Avatar
0DSX Tuning
Former Vendor
I could provide you with a new ECM, and it'd be an upgraded ECM if you have a 2006-2009.
Check it out here
Old May 20, 2017 | 06:37 PM
BlindSpot's Avatar
BlindSpot
Check it out here
Can you expand? What would be upgraded over an 09 E38? Either reply or pm me...thanks!
Old May 20, 2017 | 07:22 PM
DSX Tuning's Avatar
0DSX Tuning
Former Vendor
For you, it would add the integrator delay table for O2 sensors which can help with drivability. You'd also get a larger IFR limit for later on down the line if you ever run large injectors.
Old May 20, 2017 | 08:03 PM
BlindSpot's Avatar
BlindSpot
OK Thanks...helpful info. I'm bookmarking your WS.
To Tuners please help!!!
