Tampa Tuning Corvette Camaro Email tuning program
Former Vendor
St. Jude Donor '12
Email order tunes for stock to FBO is $175.00 for C5 and C6 Corvettes (C7 +$100) cammed $250
If you own or have "Club" access to HP Tuners software, you can Email your stock .BIN file to Tampa Tuning where it will be reviewed and enhanced for a “Email order” tune. Your tune will be enhanced by using HP Tuners 5.0x from tables in our library of almost 15000 modified configurations which have a very similar set up and modification as your make and model vehicle.
I picked up an LS2 harness for you E40 computers, but I can only do the engine side of the LS2.
What Tampa Tuning does:
- Examine and change timing tables for additional horsepower & torque gain
- Adjust fueling
- Optimize your vehicles LTFTs
- Reduction of intake air temperature table (heat soak)
- Desired rev limiter adjustments if needed
- Park, neutral, and in- gear idle adjustments with and without A/C active if needed
- Adjust power enrichment
- Engine torque management system reduced
- Transmission torque management system reduced
- Transmission shift points enhanced if needed
- Transmission shift times reduced
- Transmission shift pressure firmness enhanced
- Skip shift deleted (CAGs 1st to 4th shift)
- Cooling fan activation temperature recalculated to keep the vehicle cooler
- Perform speedometer recalibration for rear gear ratio and tire size change if needed
- manage CEL trouble codes
Tampa Tuning usually modifies your Email tune at night so you can upload and test the vehicle the next morning. During the process, usually about 3-4 scans are reviewed over a 10 day period.
If you have a ZL1 or a ZR1, I don’t mind providing an Email tunes, but for aftermarket Forced Induction, it’s not a good idea because too much can happen to fast.
Check out www.TampaTuning.com
Or best why to get me is Email me at Tuning@TampaTuning.com
Phil
- Adjust fueling
Phil
Last edited by Tampa Tuning; 03-13-2024 at 07:16 PM. Reason: Added an E40 LS2 and E92 harness
