LS7 tuner around Minneapolis?
Im from Grand Forks ND. About 4.5 hours from Minneapolis. Im certain there are no reputable tuners locally or probably closer than MSP. So, anyone have a suggestion for a tuner around Minneapolis? ND or possibly SD could work too. One negative about living in the sticks I guess!
I don't know anybody specific to Vettes, but the best tuner I've seen in the area is Shane at DB Performance in Rogers, right on your way to the cities. They do a ton of turbo and boosted applications, specializing in Mustangs and high horsepower AWD imports. I know he does a lot of GM stuff as well.
I'll be bringing mine up there for a baseline very soon before the mods start.
You may want to try working with a good tuner that will do remote. Shane Hines for example or maybe Pat G. Will require an investment in HP Tuners and an AFR2 prolly, but in the long run because of your location may be worth it.
DRM Doug Rippie Motorsports/ Waverly Mn, About 40 miles west of Rogers mn Which is right on 94. Use Saint Micheal exit. He Knows all corvette models.
