What is the Fast Relearn procedure using a GM Tech
Not sure if this is against the rules but I posted this question in another c6 forum ...
Does any one know the actual procedure to perform a FAST Relearn on a A6 with a GM Tech ll ?
I printed off some instructions but the menu to relearn is not there on my programmer
1- Chose F1 TCM module
2- F5 Module Setup
3- F0 Fast Learn Adapts
When I get to # 2 Module set up an I press enter on the next menu the only choice I have is reset Trans Oil Change .....
My Tech Two supposedly has the latest software and displays cars and trucks up to 2013
I am not sure if I am doing something wrong or maybe my TECH Two , which is a Chinese knock off does not have the programing ?
I know HP tuners can do the relearn but I don't have HP tuners ....
Dave
2- F5 Module Setup
Dave
Anybody ??
Programming with a GM Tech 2
Procedures such as relearns require programming software for which the Tech 2 acts as a pass-through device (there are other ways of reprogramming if you have different tools but that is how I use my Tech 2). The Tech 2 itself is not a programming tool and has no programming features. Although powerful, even with a CANdi module it can just diagnose issues, clear codes, and perform tests on items in your car.
Reprogramming your car's modules like ECMs and TCMs requires a PC/terminal/diagnostic tool that includes the GM programming software or subscription to a service that offers the software. For example, to reprogram an item like an ECM you would connect the PC, the Tech 2, and the car's OBD port together and download the programming software to the car via the Tech 2 using the PC. A TCM would be reprogrammed similarly.
The GM/AC Delco subscription service for programming can be found at this site:
https://www.acdelcotds.com/acdelco/action/subscribehome
You can subscribe to the Tech2Win-but you will also need a proper connector between your PC and the Tech 2 to transfer the info.
Whether it's worth investing more $$ to have programming capability depends on how often you will use it and how many cars you will use it on. It might be cheaper to just have a dealer perform the work for an hour or two of labor cost for a one-time effort.
What I've noted is just a synopsis of what's involved.
Good luck.
Good luck.
Procedures such as relearns require programming software for which the Tech 2 acts as a pass-through device Tech 2 itself is not a programming tool and has no programming features. Although powerful, even with a CANdi module it can just diagnose issues, clear codes, and perform tests on items in your car.
Kind of like clearing the Shift ADAPTS which I have done with the TECH !!
Every article I have read so far states that you go into the TCM menu then FAST LEARN ..... that is why I was asking if the menu option was missing from my knock off Tech 11 ?
If I cant find it I will go to my Transmission shop or back to the dealer
Thanks for the help
Dave
This is what I am looking to do
The" FastLearn" procedure is a series of tests that are run to allow the Transmission Control Module (TCM) to "Learn" (Adapt) to the characteristics of the clutch packs within the transmission. As each clutch packs data is learned, "FastLearn" stores the information in the adaptive cells for each clutch within the TCM. "
Transmission Fast Learn
Ok, so here is the path to Transmission Fast Learn on my "genuine" Tech 2 with software version V33.004:
Under the Diagnostics Menu, follow this path:
Transmission/Transaxle=>Automatic Transmission=>F2 Special Functions=>F0 Transmission Control Module=>F5 Fast Learn Adapt Process
Dave
Following your directions above , and I chose 2011 , I still do not see Fast Relearn , I do see Reset Fast Adapts
But if I go back and change the year and select 2006 , then the transaxle pops up and the Fast Learn is an option
I wonder if it will be ok to but my 2011 in Fast Learn mode like this since the 2006 was a six speed ?
Does yours display Fast learn if you choose a 2011 LS3 6Speed Auto? (you can back out if that is not your year car etc )
Here are some screen shots of when I choose my year 2011 LS3 6 Speed Auto
I have the latest software
I go do to diagnostics
I pick my year which is 2011
Then I pick Passenger car
Then Chevrolet , and then the next step is enter a Y ( I did not get a picture )
Then pick powertrain
then pick engine and transmission ( left the engine shot out )
Then TCM
Then Special functions
And this is the menu I see
When I chose the year 2006 I see a different menu ......with the Fast Relearn as an option
Not sure why .....
Dave
Then TCM
Not sure why .....
Dave
The menus on my Tech 2 are the same. Sorry, I do not own a 2011 C6 and do not have the 2011 Y Body Helm Service Manual to determine what's different or the same.
I went back to 06 (have 2012) but didn't see the option. All I see is the reset transmission adapts. I'll go and double check. Right now truck want shift into 2nd unless I do it manually. Think finding and running the service fast transmission adapts will make a difference? I replaced the TCM/valve body.
Dave
