C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Tune or traction control or??? Car cuts timing after a fast shift
Old 10-21-2017, 06:43 PM
Fartpipe
Fartpipe's Avatar
Default Tune or traction control or??? Car cuts timing after a fast shift
I have a 2006 C6Z06 with heads cam, intake, exhaust.
Only when I have very good traction and shift from 1st to 2nd, 2nd to 3rz and 3rd to 4th the car loses 12-16degs of timing for a random amount of time then suddenly snaps back to full timing and feels like a 100shot of hp kicking in.
If I have street tires on the car spins and literally doesn't take a single degree of timing out.
I've logged the car it shows no knock retard, coolant temp is typically in between 180-190degs, its only after a shift. Never happens in 1st gear.
Traction control turned off, complete traction control turned off.
The throttle position is not commanded shut when this happens and stays and a constant 88.0% wot during issue. Not flat shifting the car but the faster the shift the worse it is. It'll do it for a duration of 100rpm or a duration of 800rpm before it kicks in.
Thoughts on the issue and things to try.
Car already has a replacement PCM and did it with both.
Old 10-21-2017, 08:34 PM
Dcasole
Dcasole's Avatar
Received 2,241 Likes on 1,634 Posts
Torque management maybe ?
Old 10-21-2017, 10:30 PM
Fartpipe
Fartpipe's Avatar
How could I tell if it's torque management doing it?
Old 10-22-2017, 10:42 AM
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
Burst KR or torque management
Old 10-22-2017, 02:02 PM
BlindSpot
BlindSpot's Avatar
Received 1,368 Likes on 907 Posts
Do you have access to the tune? If you do in HPT, try:
Engine > Torque Management > General > TS Control System. All the way down to the bottom of that column. Disable Powerhop. Try that. If it doesn't correct it, then I'd re-enable powerhop.
Old 10-23-2017, 12:15 AM
sevinn
Support Corvetteforum!
sevinn's Avatar
St. Jude Donor '14, '16
You can log all the spark adders/reducers and torque management types.
Old 10-24-2017, 09:03 AM
Fartpipe
Fartpipe's Avatar
I just checked that's already disabled
Old 10-24-2017, 09:11 AM
sevinn
sevinn's Avatar
What about fast torque exit and all the etc limit tables? Care to share the tune or screenshot the Engine>spark tabs and Engine> Torque Mangement tabs
Old 10-24-2017, 09:28 AM
BlindSpot
BlindSpot's Avatar
OK - Stay in Engine > Torque Mgmnt > General
Can you give me the data you have in:
Torque Limit vs RPM What are all the ft. lb. values?
Tip-in Limiting (ETC limit in 2nd, 3rd, 4th gears values? Are they all the same?)
Fast Torque Exit - What are the ft.lb. values and is Spark enabled?
Based on what you have, I can give you some values to try. I needed work in these areas after going FI.
Old 10-24-2017, 09:56 AM
BlindSpot
BlindSpot's Avatar
Looks like two of us are doing similar things. So we're not tripping over each other, I'll step off here.
Old 10-24-2017, 10:02 AM
sevinn
sevinn's Avatar
No need to step off I'm sure he appreciates all the help he can get.
Old 10-24-2017, 10:09 AM
Fartpipe
Fartpipe's Avatar
Alll the help I can get!! Until this weird issue is nipped in the butt!
Old 10-24-2017, 10:43 AM
NJ_phil
NJ_phil's Avatar
A log would help to see if spark is getting pulled during the shift or when torque comes back in. Assuming an E67?
Old 10-30-2017, 08:27 PM
Fartpipe
Fartpipe's Avatar
UPDATE!
It is officially TORQUE MANAGEMENT taking out the timing.
It shows up under "TORQUE MANAGEMENT ADVANCE" it'll remove 12-16degrees of timing after each shift and wont return till top of that gear and happen again in the next.
From everything I can see i have the torque limits to 6042 and nothing that shows in the tune that torque management is even able to come into play.
It leaves me with.... WHAT enables torque management? What parameters is it using to determine taking away timing? Is there something like speed sensors, remove a fuse anything so it cant access a parameter to take it away?????
Old 10-30-2017, 08:29 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Log torque management type and see what you get. Should point you in the right direction
Old 10-30-2017, 08:35 PM
sevinn
sevinn's Avatar
How about that tune or some screenshots?
Old 10-30-2017, 09:23 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
That too
To Tune or traction control or??? Car cuts timing after a fast shift
Old 10-31-2017, 10:11 PM
Fartpipe
Fartpipe's Avatar
ok pic overload here it comes boys... and girls
Old 10-31-2017, 11:16 PM
sevinn
sevinn's Avatar
I don't see anything that jumps out in those screenshots other than the spark tcs type enabled, but I doubt that's the issue. Try logging "Spark Torque Management Type"
I guess your OS doesn't have Fast Torque Exit available. I know Dave Steck sells some 2010+ ecus that fix a ton of little issues like this because of available code updates, but I'm not sure if this would be one of them.
Old 11-02-2017, 08:11 PM
Fartpipe
Fartpipe's Avatar
Ok I went back out today, Oil starve disabled, supercharger torque mngmt disabled, spark tcs disabled. The car still managed to pull 15-13 deg's of timing for a LONNNNG time in 2nd and a blip in 3rd till i let out. I go into ETC torque limiting and the table is set to "0's" for the amount of timing it can pull. What else can i log to help find this? I'm about to burn the car to the ground!!!!!!!!!!
Quick Reply: Tune or traction control or??? Car cuts timing after a fast shift
