is this a good set up to make 550+ hp?
hello there, i have a normal aspirated ls2 that i want to modify in order to get more than 550 hp on the engine off course i want to have a high torque curve.the purouse is to take my car out on sundays and somethimes go to the track to make a desant time on the 1/4 mile
here are the parts that i have bought already but not yet put on;
.030 milled ls3 heads with flowed exhaust ports
eagle forged rods
JE forged pistons already designed for high lift valves
1.85 yella terra roller rockers
cam shaft with following specs; ADV DUR 276 292
DUR at .50 227 243
valve lift .613 .623
lobe sep 113.0
comp cam dual spring kit and stronger push rods
standard ls3 intake maniflod with throtlle body
standard oil pump with harder spring for more pressure
standardLS2 chain
i dont know if it was a good choice to have 1.85 rockers and on top such a high lift cam?
eagle forged rods
DUR at .50 227 243
lobe sep 113.0
standardLS2 chain
frederic (11-20-2017)
