C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Chuck COW vs Vitesse
Old 02-18-2018, 08:44 AM
montman
montman's Avatar
Default Chuck COW vs Vitesse
Has anyone used a Vitesse Throttle Controller and then switched to a Chuck 🐄 tune? I currently have a Vitesse and really think it made a positive difference in the responsiveness of the throttle. I don't race and I baby the car for the most part. But I do blow the carbon out a little each time I drive. What's better about the 🐄 tune for a guy like me? Thanks
Old 02-19-2018, 10:28 AM
jim2092
Support Corvetteforum!
jim2092's Avatar
St. Jude Donor '08
One is a band aid and the other is open heart surgery. Which do you want or need?
Chuck CoW (02-19-2018)
Old 02-19-2018, 10:40 AM
montman
montman's Avatar
​​​​I don't think I want or need a tune, but was just wondering if someone had actually driven cars that had the cow booster and were able to compare it with the Vitesse. I like the Vitesse because it's adjustable, - set it to Grandma's mode if someone else drives - but it doesn't add any horsepower.
Old 02-19-2018, 01:39 PM
0Chuck CoW
Former Vendor
Chuck CoW's Avatar
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Call and I'll explain over the phone.
Originally Posted by TomdaToolman
I have no actual experience with either, but will be going with the Cow because of all the problems I have read about on these forums about the Vitesse and it's defects and parts needing replacement numerous times.
Thank you.
There is NO comparison..... Those that have tried both will tell you.
The CoW BOOSTER! has a 1000% Perfect Record without 1 single failure ever.... By design, it simply can't happen.
For those willing to take risks, there are other products available....
Here's an excerpt from an e-mail I received recently.... I get these often... I've ***'d out the name.
I have been using the ******* Throttle booster and have had more trouble with it for over a year. It throws codes randomly and I have to limp it home. Today it coded and I re-calibrated it 6 times and it still hasn’t worked yet. I’ve even replaced the pedal. I’m planning on pulling it off tonight and sending it back!
To elaborate, they are NOT the same and they do NOT do the same thing the same way.
I won't go into it in this thread, but there are NO complaints with mine and plenty with the competitors.
Chuck CoW
To Chuck COW vs Vitesse
Quick Reply: Chuck COW vs Vitesse
