Wot
A diablo will not let you change the tune like you want to , it will allow you to add fuel add or subtract fuel but way to much work and risk . Taking a chance on running your car LEAN is not worth the $175.00 you will pay Lew
Lew will have you do a 2,400 RPM data log and then send you a tune to upload , then he will ask for a WIDE OPEN THROTTLE log , again he will make changes to your tune and return it , rinse and repeat as many times as you like but it only takes a couple of times to get a GREAT street tune using the Diablo plus he will send you a kick A%%SS TCM tune if you have a A4 or A6
I was very happy with the tunes Lew sent me
I ran 12.0xx with it on stock run flats with crappy 60 ft times and bad DA
Lew is a great communicator , answers your emails in a flash , I am confident you will like what you buy
Dave
Also you must test the WOT AFR's where your trans is in a 1:1 gear ratio otherwise there is not enough load on the engine to make proper readings On an auto car this is in 3rd gear at WOT --1st and 2nd gear readings are in accurate as there is not enough engine load and will always read richer---Ideally n a hot street car I would shoot for a safer 12.5 to 12.7 AFR On a dedicated race car you can lean on it a bit more and shoot for a 12.9 to 12.8 AFR
enjoy.
I read every single post and I will still eventually get Monte to tune my car. For now, my car seems to like an injector slope of +2% with headers only. WOT appears to not be pulling timing for knock so I think mine is pretty dialed in - might even be able to add some more timing or a little less fuel... but ill leave it alone until it cools down so I can test it more.
enjoy.
But to do a from scratch Header CAI tune ... I would rather have Diablow Lew do the tune as he has done thousands and knows what works
as far as having a wideband , with just a CAI header tune , because Lew has thousands of tunes at his disposal, alot done with a wideband on a dyno , he knows where to set it and can get it close ..... it's not rocket science it's just knowing where and what to change
Dave
As far as header/CAI; mine has a wrapped LS7 intake with headers. The stock 91 diablo tune did a decent job but it did run a bit lean (car kept trying to add fuel when it was cool). So I added a few percent of fuel and it seems to be running great. Mid range response went up and my LTFTs are stable (running between -2 to 2). I have a dashlogic so I'm always watching my LTFTs and KRs.
One thing I do want from Lew is to remove my rear O2s and add a little more throttle response.
