Code central, it's broke.
No I did not take it back to them as the whole experience left me with 0 confidence in their(lack of) ability. At the time I was too excited about everything that was installed and overlooked all these issues because I was told they were simply from 'being on the dyno' and they'll clear themselves after awhile. I had 0 issues with the car before I took it to the shop where I got the following installed:
Alky kit
Head swap
Blower installed
It's an 05 and the dash will read:
Service electrical system
Service ABS
Service traction control
Service active handling
Service column lock
I got a scanner and pulled the codes:
B0065
B1327
B1328
U1000
U1017
C0035
C0040
C0899
C0281
C0242
C0561
C0253
The T/C button does not work, sometimes the traction control is off, sometimes it's on. The ABS light is always on.
I also looked up all of these codes and by the sounds of it I need a brand new corvette, sadly I can't make that happen.
I was going to start by swapping the EBCM and see if that does anything.
