Hptuners now a nightmare
St. Jude Donor '08-'09-'10
I was using HPTUNERS on My c6 ls2 fron 2007 to 2014 with much success.
Now I'M trying to install it on my windows 8 laptop. At the beginning of the upload I get a message I need .NET FRAMEWORK ver 2 . I then tried
to download from microsoft and the machine goes into PDF. I then logged on to HPTUNERS web and all that had changed. I needed New USER AND PW. AND IT RECOGNIZED THE SERIAL ON MY DEVICE but wanted some APPLICATION NUMBER and I recognize no such thing. Any SUGGESTIONS WILL BE VERY MUCH APPRECIATED. LAST VER WAS BETA I uSED ON
MY DELL XP. WORKED FINE THEN. THANKS, LEON
Search your email for emails from "support@hptuners.com." Assuming you haven't deleted the emails, you should have access to your application key from your email, otherwise you may need to contact support for them to retrieve your application key based on your serial.
Im sure there support can work this out. Also if you updated a WinXP machine to Win8 I feel sorry for you. Also 8 is not a good operating system I’m sorry to report. Windows XP (don’t use not secure), Windows 7 and Windows 10 are the only decent stable OS from my professional career opinion.
Change in laptop
new passwords etc. The problem is the original disc wont
start installing until i install that framework .net. I will try the old machine now that i have new numbers from hptuners.
Thanks leon
the laptop i am using is a win8. I know many say its not like win 7. I agree . I had to get on to hp tuners site and re do
Thanks leon
Thanks leon
Finally got all my numbers from hp tuners
im sure there support can work this out. Also if you updated a winxp machine to win8 i feel sorry for you. Also 8 is not a good operating system i’m sorry to report. Windows xp (don’t use not secure), windows 7 and windows 10 are the only decent stable os from my professional career opinion.
2.0 needed to install. My new laptop which has all usb ports and no 9 pin serial connector. Im sure the usb 2.0 & 3.0 should work fine but i'm not sure.
Received 1,194 Likes
St. Jude Donor '15
i did go from win 8.1 to win 10. What a difference . I got all my numbers from hptuners and thought i should be ok to install . I still get the message framework
St. Jude Donor '15
Yeah. That was my point. If you plug serial plug into your laptop you will fry something; it's def happened before. You can't run 12V into a serial port and expect it to work very well
Suggest a forum for tech2 learning curve?
I'm getting a clone to use on my 2013 z, currently in limp mode due to me messing around with swps disconnect & running with no tp sensors. Those are other threads, look if you wish to see what I did.
LSS I am needing some tips on using the tech2 clone.
I have one now does not pass the 2 basic self tests either it's broken or it did not include the proper loopback connections (rs232) and the other one on the main cable.
Automated main PCB and VCI self tests. Not passing.
Noob on this sub forum.
So I really don't want to proceed until I have a tool the self tests ok.
I ordered another clone to try. Please don't make this into a thread about "buy the real one", ok?
Summary: Need suggestion on forum to help with tech 2, or is here ok?
This thread is about HPTuners. The title is HPTuners. The Tech2 is not HPTuners and is nothing like it. You're tagging along in a thread that has zero all to do with your question and where nobody will see it. Perhaps you should create an entirely new thread with Tech2 in the title so that people who know about the Tech2 and can help you will see it and be able to answer you.
Hope you never make a mistake like I did.
You get snarky reply's.
I did what you suggested, thanks for the great advice.
LOL, you are a funny guy, So "I can't help what goes on in there" is not snarky? Whatever. Just so you know, I have a quirky sense of humor too. To be clear, I reposted my question properly HOURS before your "help" came along. So my sense of humor tends to dry sarcasm rather than snarky.
So let's shake on it and put good info out re: the cars we love. OK?
Mpv1 hookup
I was not trying to get 12Vdc into my computer port. I know better. What I have is The plug on the HPTUNERS BOX goes to the OBDT Connector on the car. The other side of the box has a ethernet plug and that has a USB connector on the other end for the computer. I had to get a new APPLICATION KEY and I have all applicable numbers now I will try to install it tomorrow and see what happens. I also have WIN 10 much better THANKS
ORIGINALLY I HAD HP TUNERS MPV1 AND THE LAST SOFTWARE UPDATE WAS TO BETA 2.3. I KNOW THERE HAS BEEN SEVERAL RELEASES SINCE THEN.
IT GOES BACK TO 2008. NOW I HAVE a NEW LAPTOP WITH WIN 10. I TRIED TO INSTALL HP TUNERS DISC AND I GET A MESSAGE TELLING ME I NEED
.NET FRAMEWORK 2.0. I TRIED TO INSTALL MANY VERSIONS BUT THEY WONT INSTALL. THE OLD DELL HAD A 32 BUS and the NEW IS A 64. I HAVE BEEN TRYING WITH THIS INSTALLATION FOR SOME TIME. ON MONDAY I WILL HAVE SOMEONE ELSE INSTALL.
I HAVE A GREAT TUNE. PROBLEM IS IT WANTS TO STALL ON DECEL. ITS DANGEROUS TO DRIVE LIKE THIS. WOT ISN'T EVERYTHING. I GOT 500+ RW
AND I NEED TO SOLVE THIS PROBLEM. ANY COMMENTS
I always save an old laptop or 2 just for this.
St. Jude Donor '15
That is not true.. It works fine on Windows 10. Install the framework it mentions as required, install the correct drivers and install VCM suite and it will work.
Blizzard1975 (08-22-2019)
