C0040-00 error
If so chances are you got some water into some of the "wheel speed sensors"
These are located at each wheel just behind the brake rotors
This is a common issue to have fouled wheel speed sensors from either a car wash or driving in a bad rain downpour
If you replaced the indicated sensor then it may be simply a fouled pigtail Check all 4 pigtails Clean them with brake clean and make sure none of the wires are frayed and none of the weather pak connectors are bent and not making contact
If all else fails take it to a shop that has a TECH II device and they should be able to isolate the issue with the sensors the ABS /traction control/active handling All of these systems use the wheel speed sensors for input data to make them work properly
