C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Check engine code
Old Dec 15, 2021 | 11:20 AM
Mastr Fab's Avatar
Mastr Fab
Default Check engine code
My 08 is showing a U0073 code. Any suggestions on where to start looking for the problem? Thanks.
Old Dec 24, 2021 | 05:47 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
0073 is generally related to communication failure between control modules. Best to start by checking all connectors, especially those under the seats in the passenger compartment. Check for any connectors not fully seated or signs of oxidation on pins.
Old Dec 28, 2021 | 02:08 PM
Mastr Fab's Avatar
Mastr Fab
I will do that Thanks.
Old Jan 6, 2022 | 04:45 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
These cars are VERY ground sensitive and can have up to 8 different ground----Check online for all the proper ground points and make sure they are all clean and connected
Old Jan 10, 2022 | 04:06 AM
Justin._fl's Avatar
Justin._fl
5th Gear
Default I need help
My car is a 2008 c6 corvette it has a problem it was throwing up a 02 sensor code I got it fixed it was a flash check engine light the light still flashed for a min and then stopped now it comes on when I’m driving at anything above 25mph and limits power I have around 650whp but it feels less then stock when this happens idk why it starts doing a flashing check engine light again and when I try to read it there is no codes detected it says I’m new to the forums so if u message me and I don’t reply please try dm me on ig @Justin._fl thank I really appreciate some ppl say it might be a misfire but idk is anyone else having this problem thanks
To Check engine code
