C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Delivered Engine Torque
Old May 9, 2022 | 05:37 PM
BIGMAC's Avatar
BIGMAC
Default Delivered Engine Torque
Can someone enlighten me as to to role of the ECM setting for "Delivered Engine Torque" in 6L80E clutch pack survival? My transmission builder is suggesting a bad setting in the ECM tune may have resulted in clutch pack failure.
Old May 9, 2022 | 06:07 PM
TurboLX's Avatar
TurboLX
There is a background model inside the ECU that calculates a torque estimate that can be used by the TCM (and stability/traction control). It is largely based on the g/cyl air charge estimate that comes from the "virtual volumetric efficiency" calculations. So if an engine tooner doesn't take the time to get that right, it can have a knock-on effect to the trans and clutch performance.
I always tell my students that the best thing they can do to tune their trans is to make sure the engine is tuned properly. The closer VVE and virtual torque calculations are to reality, the better the trans will work.
The opposite is also true. If the VVE and/or torque estimates are wrong enough, the trans will apply the wrong pressure to the clutches and potentially fail.
Old May 10, 2022 | 06:32 AM
BIGMAC's Avatar
BIGMAC
Thanks for the response. Just to clarify- "Delivered Engine Torque" is not a direct input but is the result of calculations from data in various tables?
Old May 10, 2022 | 08:30 AM
BIGMAC's Avatar
BIGMAC
I found the post below on an LS internet forum. Does this mean the "Delivered Torque" should be manipulated to close to the rear wheel torque from the dyno runs?
BIGMAC
Dec 17, 2013
The delivered torque number can be manipulated up or down to suit the transmission tune. If the number is lower than actual, your trans will drop line pressure and smoke the clutches. Sometimes you get better trans shifting with a number a little higher than actual. There are some nice tables in EFI Live and HP Tuners that allow you to work the delivered torque number up or down to suit the build. This comes in handy when you have oversize injectors and need to scale the MAF and VE tables.
2013 Corvette Grand Sport A6 Forged 416, Greg Good ported TFS 255 LS3 heads, ECS NOVI 1500 blower, 222/242 .629/.604 121LSA Pat G cam, ARH 1 7/8" headers, NPP exhaust, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph in every day street trim.
Old May 10, 2022 | 10:46 AM
TurboLX's Avatar
TurboLX
Yes, it's a calculation. Like I said before, it's largely based upon the air charge (g/cyl) calculation from the "virtual VE" calculation. You want both numbers (aircharge and torque) to be right. You don't manipulate the torque calculation to lie to the the TCM, you just make it right. The TCM has adaptive learns based on reported torque, so it's always trying to get the clutch pressures right based on what it sees. If you lie to the TCM, it makes the wrong corrections. The TCM is actually really good at getting clutch pressure right if you feed it an accurate number for engine torque.
Old May 10, 2022 | 11:28 AM
BIGMAC's Avatar
BIGMAC
I appreciate your patience with my lack of knowledge with tuning. If I understand, the tuner first gets the actual engine torque from dyno runs. The tuner then manipulates various inputs so the ECM algorithm creates a "delivered torque" value that approximates the value from the dyno runs. Correct?
BIGMAC
Old May 10, 2022 | 03:05 PM
Orion2011's Avatar
Orion2011
Bad setting in the ECM could also mean they disabled the Torque Management in the ECM. I've see it recommended many times in tuning circles to disable that.
Old May 11, 2022 | 10:04 AM
TurboLX's Avatar
TurboLX
You're getting closer. You can't copy/paste dyno numbers right into the ECU calibration. You have to check the units. Torque models can be in either indicated torque (kind of like "revenue") or brake torque (kind of like "net profit after losses"). So you'd still have to convert from wheel torque measured by the dyno to flywheel (brake torque), and potentially to indicated torque (brake torque PLUS the friction, accessories, etc)
The good news is that the factory torque model is pretty good if you feed it a real number for g/cyl. Beyond that, it may only need some "shaping" to match your engine's torque curve as seen on the dyno. Keep in mind that the most critical part of this model for keeping the transmission happy is not actually WOT, but the part throttle region. The TCM is pretty much going to go full line pressure at WOT, but if you miss by 50Nm at part throttle, you can have a lot of slip/damage during normal driving.
Old May 11, 2022 | 10:13 AM
BIGMAC's Avatar
BIGMAC
Thanks again. This entire discussion re-affirms why I leave the tuning of my cars to the professionals!!
Old May 11, 2022 | 02:22 PM
Sub8's Avatar
Sub8
If you're lucky enough to find one of those among the ranks of commercial tooners be very pleased and treat them well😃
To Delivered Engine Torque
