The "Diablo Tune" is a 93 octane tune... and then there's the 91 Octane Tune.. The Diablo Tune has higher timing/spark advance settings, meant for the higher 93 octane gas....
I could also do a custom tune for your car to gain you even a little more than the preset canned tunes...
You can email me directly at: diablo DOT help AT gmail DOT com
You want to select/install tunes from the Tune Vehicle - Advanced Mode(or Advanced Tune) menu... And you should see a 91 Octane Tune, and the Diablo Tune...
OK, thanks. So, Diablo should be the one I want for the drag strip.
Just went through the menu. If I select easy tune the choices are 91 octane tune and 93 octane tune. If I select advance tune the choices are Diablo tune and 91 octane tune. So, that takes me back to the original question. Diablo tune or the 93 octane tune ?
Vendor covered it here.....
cliffs...Diablo tune is the biggest power gain...given 93 gas...imo
They should call it 93 or Diablo. Not different names on different screens.
Make sure you run the Update Agent program on your pc/laptop and update your inTune to all of the latest updates/fixes...
download and install the Update Agent updater program on your Windows PC/laptop - this program is used to update your inTune to the latest updates/fixes - https://www.holley.com/support/tuners/diablosport/
Once that is installed, then connect the inTune to your Windows PC/laptop and let it start up and get to the main menu screen.
Then launch/run the Update Agent updater program. It will search for and find your inTune and will start downloading any new updates. The inTune will install the updates on itself, you may need to reboot it so follow its on-screen instructions -- and when it's done and everything is up to date, the Update Agent updater program will show that your inTune is now up to date.
