C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
codes
Old Dec 28, 2024 | 11:30 PM
Smitty2006's Avatar
Smitty2006
3rd Gear
Default codes
I just bought a 2006 z06. I drove 9 hours home with no issues. I wanted to get it through emissions before the weather turned on me. On the way I got two codes P0103 and P1482. It seems like it will be a wiring issue. I was hoping maybe it's a common problem and I can get pointed in the right direction. If I have to find it the hard way what manuals do I need.
Dave Smith
Old Dec 29, 2024 | 11:05 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
A P0103 is a MAF sensor issue (sensor or wiring) and the P1482 is a cooling fan module issue which may also be a module or wiring…if you have no electrical diagnostic skills and a scan tool I’d find a auto electric or diagnostic shop in your area…you can get a 1 month subscription to Alldata DIY if you want information to fix it yourself.
Old Dec 29, 2024 | 11:08 AM
C5 Diag's Avatar
C5 Diag
To codes
