C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Vcm scanner help
Old Aug 4, 2025 | 11:29 AM
Smokehouse00's Avatar
Smokehouse00
Default Vcm scanner help
Anytime I run a scan my fuel pressure never changes. So I pulled the fuse pump relay and the car died. But pressure still didn't change. Where can I get an accurate fuel pressure with the vcm scanner
Old Aug 4, 2025 | 06:04 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
What is your VCM Scanner ??…I have a few $2000 plus factory level aftermarket scanners that don’t show fuel pressure…get a fuel pressure gauge…if you had a car like a C7 Corvette with a high pressure fuel pump you can view this fuel pressure because it has a fuel rail pressure sensor.
Old Aug 5, 2025 | 08:31 AM
DarkC-6's Avatar
DarkC-6
VCM Scanner is one of the HPTuners apps used with their MPVI device. C6 corvettes don't have a fuel pressure sensor - the scanner just displays a virtual 58psi. You will need to add an actual fuel pressure sensor to log fuel pressure.
To Vcm scanner help
